Simulate Signal phase shifting loop
I am trying to use a loop to phase shift a simulated signal across 360 deg. My loop will change amplitude, frequency, offset, but it won't change the phase, does anyone know how I can do this? I have attached a code that shows the fundamental problem.
(4,195 Views)
Also - I know it's not wired correctly, but it won't work with either signal generator.
(4,177 Views)
When you wire a graph to it and set the graph to ignore timestamps, you see the phase shift. If you wire a chart to it, wire a true constant to the reset input of the simulate signal.
(4,171 Views)
Accepted by vandej
Great! I really should of tried of the reset signal input. Thanks!
(4,168 Views)
