Simulation Interface Toolkit support for Matlab R2006b, Labview 7.1
Does the latest Simulation Interface Toolkit v4.0 support Matlab R2006b?  The readme file posted here seems to indicate so, however the data sheet posted here does not make the same claim.  Also, regarding supported Labview versions, the data sheet claims Labview v7.1 or newer is supported, while the readme file claims Labview 8.5 is required.  Which is correct?
Paul Minear
Applied Research Lab
The Pennsylvania State University
(3,015 Views)
Hi paul
The readme file is the one containing the correct information, so you require labVIEW 8.5 and Mabtlab R2006b is supported. The data sheet that you are looking at does not appear to refer to any particular version of the toolkit.
Regards
Beejal
Beejal S
NI UK & Ireland
(3,004 Views)
