DAQmx physical channel error message
I am new to Labview but I managed to create a new analogue voltage input task in Measurement and Automation Explorer. I am using DAQmx create virtual channel VI but  I am getting an error message saying that "required input physical channel is not wired". Any idea why I am getting this error message. Also what is the difference between using DAQmx Assistant and using VI's like DAQmx create virtual channel, DAQmx timing etc.Any help is appreciated.
Duran
(3,955 Views)
The first VI 'Create Virtual Cannel' has an input called physical channel. This needs an input. Right click on the terminal and select Create>Constant. Then you can select the channel (something like Dev1/ai0).
To your 2nd Q: The assistant is a fast way to configure your measurement. You can later also convert it to the VIs you use now. Using the VIs gives you full programmatically control of the task. (The meaningful phrases are 'configure' and 'full programmatically').
Felix
(3,946 Views)
You don't need to use the DAQmx Create Channel if you have an existing task with channels defined. You would only use this if you want to add channels to an existing task or if you wanted to not use an existing task at all and define everything in the VI. Personally, I create the task in the VI and then I don't have to worry about what is or isn't defined in MAX.
(3,946 Views)
Hi Felix
Thanks for your help, another question I want ask is how do you convert the assistant into VI's.
Regards
Duran
(3,924 Views)
Right-click on it and select Open Front Panel. On the Blockdiagram you now see all the VIs used for that Configuration.
Felix
(3,913 Views)
