Simulink Model to LabView VI converter
Does anyone know how to convert simulink model into labview VI.i have used Control Design and Simulation toolkit for it.but it gives loads of error.I m trying to convert FHSS model to LABVIEW VI.so if anyone can please help.Also if someone know or if some has the vi for creating the hopping sequence for FHSS in labview. I  only need help regard generating hopping sequence in labview.
Message 1 of 13
(14,058 Views)
Please keep your question in one thread.
And you still have not told us what a 'hopping sequence' is.
Cory K
Message 2 of 13
(14,053 Views)
Thread hopping? 😉
-AK2DM
Message 3 of 13
(14,049 Views)
What does it mean to keep a question in one thread?
 Hopping sequence is used in frequency hopping spread spectrum by a signal to hop to a new frequency..In FHSS we mutlipy FSK modulated signal with the hopping sequence so tht fsk modulated signal shud jump to the new frequency.
Message 4 of 13
(14,044 Views)
It means that it was not necessary to open two different topics in the forum for your problem.
I don't know anything about FHSS in labview but I can help you for the Control and Design Simulation Toolkit.
The toolkit SIT (Simulink Interface Toolkit) doesn't convert a model in a labview VI, but generate a dll which you'll be able to call and manipulate in Labview with SIT.
First of all you have to define the IN/OUT signals in your model by opening it in matlab-simulink and adding the labview specific terminals.
Then you'll have to build your dll with the Matlab Real-Time Workshop by selecting the "System Target File" nidll.tlc.
You'll find some help here : http://zone.ni.com/devzone/cda/tut/p/id/3583
When the dll is built, you'll have to open the SIT connection manager in Labview\Tools and select your new dll.
When the IN/OUT signals are assigned with the SIT connection manager, you'll be able to use the SIT functions to call your model (in the dll) and get values from it.
Gilles
Gilles K.
Electronic System Engineer, Renault F1
Message 5 of 13
(14,014 Views)
I'm dealing currently with the same task, and i wonder if once you create the .dll that you can call and manipulate, if you can integrate it in a block diagram already done... To be more specific, I am testing different types of controllers, and I only need to convert the simulink models into .vi's that represent the controllers. The rest (read signals, write in memory, etc)all that is already in a block diagram. I don't know if with the SIT conector you can call the .dll with VI blocks.
I'd use the somulation model converter, but it doesn't work pretty well... my .mdl is kind of huge...
Please, if you worked out your doubt, maybe you can help me... i'd appreciate it a lot.
thankx
Message 6 of 13
(13,722 Views)
Hello Fonsdecelis,
Yes you can do this. You would need to use the use the Simulation Interface Toolkit VIs to access your .dll and I have attached the help file provides a brief description for what each VI does and links to other help file explaining them in more detail. I hope this information helps you with this.
User Interface VIs
http://zone.ni.com/reference/en-XX/help/371504E-01/lvsit/user_interface_vis/
Model Interface VIs
http://zone.ni.com/reference/en-XX/help/371504E-01/lvsit/model_interface_vis/
JimS.
Jim St
RF Product Support Engineer
Message 7 of 13
(13,641 Views)
If you have Control Design and Simulation Module, you can use the Model Converter to convert your .mdl to LabVIEW VIs.
Andy Chang
Message 8 of 13
(13,636 Views)
I am doing my engineering 2nd year.
I am new to matlab and labview. Can you please send me the FHSS simulink model to salman26ec@gmail.com.
Thanks in advance.
Salman
Message 9 of 13
(12,170 Views)
please send me the simulink model of fhss
Message 10 of 13
(11,142 Views)
