Simulink a Control design a simulation aydua con modelo
it so rare, The outputs of this Vi are Transformer's currents so must to be sinusoidal signals too, when I  run th VI The problem is this:
First the Vi start to run, but the signal decrece so fast and in the end The error persists
18979i6BEF322DBB37634E
The corrects results should be :
18981iBF245C6A2D80EAB8
The Block Diagram of this circuit is based in a Simulink Diagram
18983iA780BBEF1F379238
is so frustrate jeje, but maybe is a configuration error, i don't know what to do.
Sorry for the inconvenience but I really need to resolve this
Vendetta
Message 11 of 18
(1,878 Views)
Hello Vendetta,
I assume that this is an example from a textbook? What are the inputs ln_v1 and ln_v2? Is there any additional information in the textbook regarding this model that perhaps we are missing?
Andy Chang
Message 12 of 18
(1,867 Views)
well in fact The name of  The the textbook is
Dynamic Simulations of Electric Machinery: Using MATLAB/SIMULINK
Prentice-Hall PTR 1998, ISBN 0-13-723785-5
Chee-Mun Ong
 cap4
But, there no parameters, so in INTERNET i found a Document with this implementation and, with some changes, in other document the model is similarity.  In my proyect i must to make the following simulations: The  Transformer lineal and No lineal case (saturation) and variable Frecuency i attach the documents,  the textbook have a big size , this is the reason why i didn't attached
But, there no parameters, so in INTERNET i found a Document with this implementation and, with some changes, in other document the model is similarity.  In my proyect i must to make the following simulations: The  Transformer lineal and No lineal case (saturation) and variable Frecuency i attach the documents,  the textbook have a big size , this is the reason why i didn't attached.
In the first document (no linear) you will found a proyect in simulink. there are a diagram block is similar to what we have been working
Figure 5 i already tried this diagram and i have not worked, i hope you find it usefull.  here you will find the voltages and the results should be obtained in fact, the autors used equation of the Textbook before mentioned
Thanks for your interest in helping
Vendetta
Message 13 of 18
(1,857 Views)
Hi!!
Here i found the solution in mathlab code in the offical page of the bookText, attach this, may be can help you too
The resolution is there
http://cobweb.ecn.purdue.edu/~ong/
Simulink and Matlab files
C4 after click en sla.m  or sla.mdl
anyway i  copied and pasted it into a document
Take care
Vendetta
Message 14 of 18
(1,850 Views)
Do you know the two inputs that were used for simulation?
Also each of the integrators seem to have an initial condition as well.
Andy Chang
Message 15 of 18
(1,837 Views)
I am trying to modelling a tank system and I had the same error "Error - 2335" But i have checked everything and I don't get what's wrong. I am using Labview2011, I send the file, if anyone can help me I really will apprecciate it.
Message 16 of 18
(1,686 Views)
DMX,
What are the differential equations that describe your system? The sqrt introduces negative terms and it seems to drive h_2 to inifity.
Andy Chang
Message 17 of 18
(1,683 Views)
The equations are attached. But I just implemented the same scheme in Simulink an it worked, because h1 is allways greater than h2. I really do not understand because I did the same model in Simulink
Message 18 of 18
(1,681 Views)
