Simultaneous running of multiple SubVIs
Hi, I'm trying run 4 SubVIs from a mainl VI at the same time. The SubVIs plotted data adquisition and the main Vl select the plot to show.
How should I do to run all without having to open it?
PD: Gráfica => Plot
Message 1 of 17
(5,506 Views)
Hi rvenge,
you can run subVIs without showing their frontpanel. (Btw. its default to not show the frontpanel of a subVI.)
When they should run in parallel you should place them in parallel (without data dependencies, THINK DATAFLOW)! Right now you (seem to) call them in different cases of a case structure: that's not "in parallel"...
Message 2 of 17
(5,505 Views)
Accepted by rvenge
Since you are already using a VI reference for showing the front panel, you could use an Invoke Node to run the subVI.  Be sure to set the Wait Until Done to FALSE.
Message 3 of 17
(5,498 Views)
And how I must use the invoke node?
Sorry I don't have a lot of experience with this functions
Message 4 of 17
(5,451 Views)
select application control palette - invoke node , right click, select class- vi server - vi
then select method run vi
Message 5 of 17
(5,443 Views)
Thaks Neos.
I have an error, and I don't know how must use the invoke node or where must be used.
Message 6 of 17
(5,405 Views)
Did you use same vi's reference on its block diagram and tried to run it?
Message 7 of 17
(5,400 Views)
Yes, but I've changed it and run correctly. Thanks
Message 8 of 17
(5,391 Views)
not allergic to kudos
Message 9 of 17
(5,389 Views)
Don't work again. The same error! and I don't know why.
Message 10 of 17
(5,353 Views)
