Simultaneous waveform fetch from multiple channels in DPO 7104
I am trying to fetch the same signal on two channels to see if there's a timing difference between two channels of the scope, using the NI driver function:
"tkdpo7k Read (Multiple Waveforms).vi". However this VI seems to fetch waveforms fomr channels sequentially rather than simultaneously, resulting in a time delayed version of the same signal on one channel vs. the other one.
I was wondering if there may e another function to acquire waveforms on two channels simultaneously, tried using two instances of "tkdpo7k Read (Single Waveform).vi", in Labview, but still, they do not run at the same time.
Help anyone?
Message 1 of 16
(4,895 Views)
The very nature of these types of instrument require a sequential waveform transfer. However, if you have done the setup correctly, the scope will have acquired them simultaneously and the sequential transfer is totally irrelevant.
Message 2 of 16
(4,890 Views)
Can you please tell me which setup parameter needs to be modified to make that happen? The two channels seem to be captured simultaneously on scope display, but in Labview they seem to be not in sync.
Message 3 of 16
(4,888 Views)
If the scope is capturing them, then it is probably setup correctly. You have not supplied any images or your code that describes what you mean by 'not in 'sync'.
Message 4 of 16
(4,880 Views)
Here's the same signal on two channels....
Message 5 of 16
(4,875 Views)
This is from the unmodified example called Tektronix 7000 Series Acquire Multiple Waveform?
Message 6 of 16
(4,864 Views)
Message 7 of 16
(4,863 Views)
Yes, code attached.
Message 8 of 16
(4,861 Views)
You did not attach any code - an image is not the same thing and that was not my question. I asked if you were using the top level example program that I mentioned.
Message 9 of 16
(4,858 Views)
Accepted by Roxanne
Yes, I am using the example vi (tkdpo7k\tkdpo7k.llb\tkdpo7k Acquire Multiple Waveform Example.vi) from tkdpo7k.llb driver downloaded from NI webiste, which calls "acquire multiple waveforms).
Message 10 of 16
(4,855 Views)
