Simultaneously Read Analog Voltage and Termocouple
My current VI is reading in thermocouples data and generating an excel report, as well as outputting a digital signal. I was asked to read in a voltage at the beginning of the test, and a voltage from a current probe while simultaneously reading in the thermocouple data. It sounded simple enough, but I haven't successfully added this feature to the VI. I either get a resource error or the data acquisition become entirely too slow to be useful. I'm using two NI 9211 cards to acquire the thermocouple voltage and a NI 9219 to acquire the analog voltage. Does anyone have any suggestions as to what I may be doing wrong or a suggestion of a solution?
I've attached a screen shot of the code where I'm acquiring data, as well as a copy of the VI. Sorry it may look a little messy. It has been a growing project and a compilation of a few different codes.
(2,991 Views)
Can you start from a fresh VI and program what you want to achieve? We can then understand the issue properly and help you with issues.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,986 Views)
I've attached a much more simplified version of my vi. The main problem is when I add the read voltage channel to the vi the sample rate goes way down to about 2 S/s. Even though the NI 9219 has a sample rate of 100 S/s.
(2,980 Views)
Accepted by topic author ee_hokie
I figured out that I was simply missing the DAQmx timing VI and creating a simple timing clock.
(2,936 Views)
