usb ports manage control
Hello at all, I am trying to develop an application to control the accesses to the USB ports.
There is an application that is running which at the moment that the unit is connected to the usb port, this it detects it and it begins the test, I need that my application takes the control of the usb port, read the unit serial number, realize some tasks and later liberate this unit or the usb port so that the application that this running initially takes the unit and begin the test.
I'm not sure if I explain me correctly but if someone has an idea or some suggestion it will be appreciated
(2,128 Views)
Shane's Nugget on USB may be of use.
It is a mulitpart nugget so look for the updates as well.
Ben
(2,124 Views)
