Sin wave generation for R series FPGA
Dear All,
I am generating sin Wave with (FPGA Sin Wave Generation Express vi) from Rseries FPGA Target.Frequency range is from 1500Hz to 3000Hz.Frequency and Amplitude parameters are coming from Host .Wave is going to an AO.The wave is not displaying in my Host with the set parameters as required.
What am I doing wrong??
Certified LabVIEW Architect
Certified TestStand Architect
(2,942 Views)
What hardware are you using to display the AO? Or are you sending the AO back to the host?
(2,878 Views)
I am using NI 9263 4x AO.the problem was with the FPGA Express vi Parameters used the example sin wave Generation from the FPGA fundamental folder and modified the Host parameters to meet our requirement and it worked fine.
(2,873 Views)
