Sine Sweep
I´m currently trying to generate a sine sweep Test with the HS3 Generator from TiePie.
I already found a working signal generation, but I need to transfer it to the vi`s that are running the generator, which are connected to LabView via a libtiepie.dll, since the HS3 is no Ni-module.
I creat a 1D array of doubles and have to hand it to the vi by using a pointer to a buffer with the waveform data in the form of single.
Does anyone knows how to create such a pBuffer?
I´m quite new in using LabView, so I hope someone can help me out.
Thanks in advance
(1,563 Views)
Continued in the German www.labviewforum.de
(Please mark crossposts on your own!)
(1,525 Views)
