Single Random Number from Gaussian with defined variance
Hi folks,
I'm new to LabView and was hoping someone could give me some pointers.
I need to generate a single random number from a Gaussian distribution of
defined variance.
This step is part of a for-loop (i.e., for each iteration, the variance changes).
Does anyone have suggestions as to how to do this most efficiently?
I realize there is a Gaussian White Noise function, and that I can specify
an array of length=1.
But the seed then needs to be changed for every step of the For-loop.
Is there an elegant solution to this that someone has already written?
Thanks in advanced for the help. Cheers,
erik
(4,982 Views)
Erik Hom wrote:
> Hi folks,
> defined variance.
> erik
Erik,
there's a random number generator in the numeric function palette.
The output is 0-1. You could s
ubtract 0.5 for zero mean, and multiply
the result for whatever variance you need.
Walter
(4,982 Views)
In article <38444E8D.58CC9209@brokersys.com>, Walter Petermann wrote:
>> defined variance.
> Erik,
> The output is 0-1. You could subtract 0.5 for zero mean, and multiply
> Walter
Walter,
that would end up in a linear distribution, not in a Gaussian distribution.
Eric,
'feed' the Gaussian distribution vi with that linear random number should solve
your problem.
Greetings from Germany
Henrik
---------------------------- Corinna & Henrik Volkers
volkers@freebsd.first.gmd.de
__|._.__|._.__|._.____
________________ beeeeeeeeeeeeee...
(4,982 Views)
