The non-array
I want to select multiple columns of an two dimensional array. My test
example is this:
1 2 3
4 5 6
7 8 9
I want to select columns 1 and 3 to get
1 3
4 6
7 9
It is easy to select the columns via a boolean array and a case in an
auto indexing for loop. But I didn't find any way to create an empty
array to reassemble the columns. I always get
1 0 3
4 0 6
7 0 9
This way the number of columns stays constant. I tried to use a non
initialized array constant and an array of length 0 in the false
(non selecting) case as a compulsory output. Cheating by using local
variables is no clean way of data flow programming.
I don't want to reinvent the wheel by reading the data from file as
text and chopping it up to provide empty strings in th
e right
places. I have to use the numeric values afterwards to subtract them
from the first row. Read from spreadsheet is the good way of doing it
but leads to the trouble with arrays.
Is there a clean way of doing it?
Johannes Niess
(3,787 Views)
I think you should use the array function: array subset (or something like
that) I presume you use LAbView 5.x or so.
The help-files give a perfect example of this function. After you created 2
1D-arrays, you can join them by the function build array.
Boozz.
please let me know if this is what you're asking
use: r.oude.vrielink@hetnet.nl
Grusse, ronald
Johannes Niess schreef in berichtnieuws
m2ogc1xma8.fsf@server.landtechnik.uni-bonn.de...
> Hello,
> example is this:
> 1 2 3
> 4 5 6
> 7 8 9
> 1 3
> 4 6
> 7 9
> 1 0 3
> 4 0 6
> 7 0 9
> text and chopping it up to provide empty strings in the right
> Johannes Niess
(3,787 Views)
Ronald,
The core of the problem is that autoindexing only has one internal
variable for both input and output dimension. This behavior forces
array length (output):= array length (input)
It is easy to select the right parts. The problem is to reassemble the
selected pieces from a for/while loop.
Johannes Niess
"Boozz" writes:
> Boozz.
> Grusse, ronald
> Johannes Niess nn.de> schreef in berichtnieuws
> > Hello,
> > example is this:
> > 1 2 3
> > 4 5 6
> > 7 8 9
> > 1 3
> > 4 6
> > 7 9
> > 1 0 3
> > 4 0 6
> > 7 0 9
> > Johannes Niess
(3,787 Views)
What do you need for/while loops for?
In my opinion the question is as follows:
There's a 2D array:
123
456
789
You split it up into 2 1D arrays
1
4
7
and
3
6
9
And then the two 1D arrays are assembled into a 2D array.
13
46
79
Oder habe ich die frage nicht gut verstanden?
Ronald
m2iu28vdam.fsf@server.landtechnik.uni-bonn.de...
> Ronald,
> Johannes Niess
> "Boozz" writes:
like
created 2
> > Boozz.
> > Grusse, ronald
> > > Hello,
> > > example is this:
> > > 1 2 3
> > > 4 5 6
> > > 7 8 9
> > > 1 3
> > > 4 6
> > > 7 9
> > > 1 0 3
> > > 4 0 6
> > > 7 0 9
> > > Johannes Niess
(3,787 Views)
"Boozz" writes:
My real data file is a lot bigger and numbers of columns and rows
vary. And IMO it is "natural" to use auto indexing and a boolean 1D
array to select columns.
> There's a 2D array:
> 123
> 456
> 789
> 1
> 4
> 7
Array Subset icon #1
> and
> 3
> 6
> 9
Array Subset icon #2
> 13
> 46
> 79
Its easy to do in a "parallel" approach. But it is unfeasible with big
number of varying columns. Thats why I need the loops. I'll attach a
minimum example in private mail to Roland and I can send it on request to
anyb
ody interested.
Johannes Niess
(3,787 Views)
