Single beep when within temperature range
Hello. I have an issue. I have a project where I want a beep when the temperature changes.
I have 3 categories. Hot, warm, and cold. Cold(0-25 degrees), Warm (26- 60 degrees) Hot (61-100 degrees).
Is there any function I can use to get a beep for when the temperature changes from its category?
I know how to get the beep. The problem I'm facing is preventing the beep when it is still within the same category.
(2,482 Views)
Accepted by topic author Rayhl
Sounds like you want a function that checks if a threshold has been crossed. Then set a boolean to true, then check if you need to "beep".
Are getting hung up on the logic? Or just cant find the correct BD functions palette?
Former Certified LabVIEW Developer (CLD)
(2,478 Views)
Use a feedback node and compare the previous category to the current category and beep if they differ.
(2,459 Views)
Hellooo thanks for both of your replies. I managed to get the simulation to work. I used the (is value changed) pallet to prevent the beep from reoccurring even tho its within the range of the category.
(2,417 Views)
Hi Ray,
do you really need so many comparisons and boolean operations for such a simple task?
(2,394 Views)
