Singleshot configuration vs software trigger
I dont know if my approach if feasable. I configured my generator as singleshot and software edge trigger. After configuration and using "Initiate generation", one desired signal gets generated, but when I use "NiFgen Send Software Edge Trigger" afterwards no signal gets generated.
Generator: PXI-5441
Actor Framework
(1,251 Views)
Accepted by topic author Quiztus2
I had to switch to stepped burst instead of single trigger mode
Actor Framework
(1,209 Views)
