Sizing 50 controls/indicators on the front panel to look similar
Hello
I have 50 bollean rectangular indicators on the front panel. For some reason the sizes of few indicator are slightly different than the others. If I resize them using mouse it oversizes it. Cant think of an intuitive method to achieve this.
Any ideas!
Kind Regards
Austin
(2,538 Views)
Accepted by K.Waris
Resize Objects -> Minimum Height and Width.  or is it Minimum Width and Height, I forget....
(2,536 Views)
(2,530 Views)
Austin,
If this is something you may use frequently, make a strict typedef of one that is sized correctly.  Then replace the others with the type def.
Lynn
(2,526 Views)
Thats clever
Didnt think of that
Austin
(2,522 Views)
You can also create a 1D or 2D array of indicators in which case they'll be as big and the handling might be easier ... although you cant place them as freely.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,510 Views)
