11-12-2010 08:01 AM
More of interest in this case is the flow of setup and reading commands you use for the 34401 😉
11-14-2010 07:23 PM
I'm not sure what level of detail you require but I am using Configure measuremen.vi and Read single point.vi (set to AC voltage). There is no additional setup and flow beyond what I have described - I consider this two be two very straightforward volatge measurements.
11-15-2010 04:40 PM
I was wondering how you are connected to your device? Also are you using this instrument driver to talk to your device? I would recommend taking a look at some of the examples in there to see if they help out.
Best Regards,
Adam G
11-15-2010 06:16 PM
That is the driver I am using. I had a look through the examples already but nothing helps to solve this issue.
11-16-2010 03:19 PM
Do you have another way to communicate with the device that is not through LabVIEW that you can use to test the speed? Also have you tried contacting Agilent about the slow speeds?
Best Regards,
Adam G
