Slow TCP Communication between PC and RT Desktop
Ed,
We are using NI Real-Time Phar Lap ETS 13.1
I wrote a handcrafted function in C that doesn't exist in LabVIEW and compiled it into a DLL using Visual Studios 2010 (execution was too slow when I attempted to write the function in LabVIEW). I ran the DLL through the 2015 checker for RT deployment, and there were no Bad functions indicated only several Stubbed functions. When I attempted to actually deploy and use the DLL, however, it still kept failing most probably due to said Stubbed functions. After spending several months trying to solve that, I decided to simply leave it on a Windows OS comp where I knew it did work and transmit the data back and forth. Not an ideal situation, perhaps, but it let me get on with my work at least. When this communication issue came up, I decided to revisit trying to put the DLL onto the RTOS to by-pass the problem altogether. However, even after upgrading to LabVIEW 2016, the DLL still failed.
I hadn't really considered attempting a direct connection mainly because we will need the router to connect the Host computer to our RT Target, and we do not currently posses an additional Ethernet card that we could add to the RT Target to allow for a second connection.
Regards
Message 11 of 12
(803 Views)
Hey,
Do you have LabWindows/CVI with the Real Time Module?
You could try re-generating the DLL for your RT and then you won't need to have communication back and forth to perform these calculations. I have not done this in a while but it might be worth trying out the documents I have linked below:
http://www.ni.com/pdf/manuals/374686d.pdf (pages 6-7)
http://www.ni.com/tutorial/4583/en/#toc7
This may overcome the actual need for TCP communication for the most part.
Message 12 of 12
(776 Views)
