Slow button navigation event response
I upload a demo interface to demonstrate a problem that I encounter.
I use a tab control and "OK Buttons" to change tabs.
The appearance of the "OK buttons" is changed by pasting images from Microsoft Visio, through Button's right click-> Advanced -> Customize.
The clicks on the "OK Buttons" are captured using the "Value Change" in an "Event Structure".
The problem is that sometimes an "OK Button" needs more than 1 click to work. In the original interface which has more decorations, the "OK Buttons" need many ....many... clicks to go to another tab.
What is more, the tabs are not clickable when the program is in "Run mode".
What should I change?
Thank you.
Message 1 of 12
(6,146 Views)
Most likely your clicks miss the button. You should make the button the same size as the image. Also, make the button transparent and be sure it is in front of the image so that the click registers.  Note in the image below that I moved the arrow to reveal the underlying button. If you do not click where the button is, it does not activate the button.
Why would you want an event structure inside a timed loop?  Use a regular while loop. Make sure you have a stop button and an event case for its value changed event.
Lynn
Message 2 of 12
(6,133 Views)
Hello!
The button does not need to be the same size as the image behind which it is hided.
In the page 3 of the Tab Control, you can see a big image behind which the button has the regular size. If you click at a corner of the image, it works.
The Timed Loop is the loop that runs the program. If I use a while loop then the program runs every single possigle instance and has a great CPU usage.
That's why I use the Event Structure inside the Timed Loop.
If I put the Event Structure inside a While Loop which is out of the Timed Loop, then I see in my orignal interface that the performance is better, but there is still some latency.
So, which is the correct way to have the proper time performance at event handling of decorated buttons?
Message 3 of 12
(6,117 Views)
Well, Lynn is typically right, so don't dismiss his advice.
Whatever you are doing is just plain ugly. You should import at the same size.
Thank statement makes no sense. The loop only spins when an event occurs and that would be the same with a plain old while loop. You don't wire a timeout on the event structure, so the timeout will never occur. Why would you use all the complications of a timed loop if never has control over the configured loop rate?
That makes little sense either. How do you measure "performance"? All the time loop is prevent successive events to ocur faster than 100ms apart. I doubt you'll be able to press that fast, especially since tabs are switched and the click position changes between tabs.
Well, do the suggested changes and see how things improve. Then post back.
Message 4 of 12
(6,084 Views)
When I replace the Timed Loop with a While Loop, then the CPU usage of the LabView process is 50%.
How can I make the button transparent?
How do you explain the fact that the event is triggered when a click is occured at a point of the image that is not over the button that is hided behind?
Message 5 of 12
(6,055 Views)
Please attach your code. If I take your code and right-click the wtimed loop...replace with while loop, wire a stop button to the termination condition, and run the VI, CPU use is negligible (as expected). You must be doing more than just that.
What button? Please be more specific!
That is normal behavior. No need to explain anything.
Message 6 of 12
(6,050 Views)
I looked at the controls again. It seems that clicking within the bounds of the label does not activate the button but clicking anywhere else within the decal works.
Lynn
Message 7 of 12
(6,045 Views)
Yes, exactly. Some labels are on top of the decals, thus excluding some areas from click detection.
Message 8 of 12
(6,041 Views)
If the Labels are not at the top of the decals, they will not be visible. But if they are on top they exclude a clickable area. So?
If I make the buttons bigger than the images, I need to make them transparent, but I don't find how I can do that.
I attach the vi file again, this time with the while loop. It doesn't seem to occupy 50% of the CPU usage, but my original interface does it, having similar code.
Message 9 of 12
(6,024 Views)
Accepted by nikosfs
Use the boolean text and hide the label
You need to import the pictures into the button, not the decals. (see the button in page 2 I have modified in the attached VI. I did not hcange anything else....).
You probably wired a zero to the timeout.
Also, for latch action buttons, terminals belong into the respective events. Note also the coercion. You enum diagram constant is of the wrong type.
Message 10 of 12
(6,015 Views)
