Slow down the impact in labview
I want to ask if there is any way to slow down the impact in labview. For example, if I adjust the Knob to 10, the Gauge will not increase immediately to 10, but will increase slowly up to 10. When I adjust the Knob, the Gauge will change as well, but slowly Knob. Thank you guys!
(3,694 Views)
Hi khan,
maybe it would help to answer your question if you would explain about which knob and gauge you are talking about!
There's no reason a "gauge will not increase immediatly" - apart from your code…
Please attach your VI!
(3,656 Views)
I'd treat the changed value as a setpoint.
Then the code should have a function to go to that setpoint. This could be a ramp, or a P, PI, PID function. Even a cosine function.
The interpolation needs to be programmed, and the details depend totally on the program you have. In a new blanc VI, you'd first need some structure. This could be a Producer\Consumer, state machine, the usual suspects... This is actually CLD level coding.
It would be feasible to make a control and indicator, and design a VI that handles the transition from the indicator's current value to the control's value. If that is practical, again, depends on the program you have or are planning.
(3,638 Views)
Accepted by khanhpham_3108
Here is a motion ramp that we used for our robot. It calculates the accel deccel and steady state time and generates a curve. We used this curve and a PID loop to make the move happen. You should be able to do something like this to do what you want. This code also assumes that you are starting at zero and moving to a max point. You will have to change it to do what you need it to do.
Tim
GHSP
(3,619 Views)
Do you want a maximum rate of change? Should be trivial to implement with a shift register.
Another option would be an simple exponential filter (see here). Can you give us more details on the requirements?
(3,587 Views)
Thanks. You can sent to me your code, please?
(3,545 Views)
thank you so much!
(3,537 Views)
