Slow edit using JKI and DQMH
Hello to all,
Recently i'm in a new situation where I have a slow labview performance at the block diagram when I copy objects or when I save the vi. For example, copy takes more than a second or two (i'm faster than Labview) and save takes more than 5 seconds.
I started to search in the forum for similar issues and one cause is the size of the VI. That people considered a Main.vi bigger than 1.5MB to be extremely large. But I can easily achieve those values with a simple project like the one that I attach (a very simple one where I use a JKI state machine and some DQMH modules - i'm starting on DQMH).
I asked a friend to test with his projects and he has the same thing. Usually the size is easily between 1MB and 2MB.
But it's normal to take so long with a size like do one that I mention?
Jorge Amaral
Software developer
www.mcm-electronics.com
PORTUGAL
(2,987 Views)
My super-busiest "main" VI is 25 kB.  Saving big default data on your FP (or in constants) will certainly bloat your file size.  So will not separating your compiled code from the source.  And of course, not using subVIs will do that to you, too.
All of those things aren't recommended practices.
Anything like that going on?
Bill
CLD
(Mid-Level minion.)
(2,928 Views)
That's really a small size. I placed a JKI state machine in a new VI and the value on the block diagram is 250K. So I don't know how you can do it.
The small example that I attach communicates with two spectrometers, one camera and uses a NI MIO.
Can you describe what are you doing on your "super-busiest" main?
Thanks for your help!
Software developer
PORTUGAL
(2,896 Views)
Sure, I have several loops doing different things with two queues and several dynamic events.  It is highly modularized, though  I don't really have anything but subVIs at the main.vi level.  That's probably why it's so small.  All my loops are in subVIs.  The complexity is 0.5.
Bill
CLD
(Mid-Level minion.)
(2,885 Views)
I see where I'm misunderstanding.  You're talking about total memory, not physical size on the disk.  I am sorry.  I have a similar memory footprint.
Bill
CLD
(Mid-Level minion.)
(2,881 Views)
