Small UI pipes pixel
I have a 2D treating plant graphicdisplaying pumps, valves, tanks and pipes. The pipes require control over the color, size and location during development and programmatically. I have stumbled on the simple string indicator which works fine as a pipe but I cannot get the pixel size below 5 for my small pipes. Any ideas, thanks.
Message 1 of 15
(4,445 Views)
Have you tried using decorations, instead?
Bill
CLD
(Mid-Level minion.)
Message 2 of 15
(4,441 Views)
I have and still see the same limitations.
Message 3 of 15
(4,428 Views)
Would a picture ring work?
http://zone.ni.com/reference/en-XX/help/371361N-01/lvhowto/addingpictitemstoringcntrl/
You can make the pipe image as small as you like. You can also play with matching picture background colors if the sizing is not ideal.
Feel free. Contact me for anything more,
    Pang
You too can be LabVIEW Awesome!
Message 4 of 15
(4,402 Views)
That is a path but a rough one.  I would like to keep the control as simple as possible because there will be 20-100 pipes on 1 vi.  The pic box will give me a small pipe but not the flexibility as I would like.  I just can not see how all the decoration, indicators and controls are locked into a min of 5 pixels.
Message 5 of 15
(4,389 Views)
make your whole pipe system as ascii art, then the pipes can be quite thin
__________________
Engage! using LV2015
Message 6 of 15
(4,386 Views)
You could use the 2D functions to paint the systems as a big picture and in that process change tubes and similar.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 15
(4,344 Views)
If I had 1 graphic to build I could see that approach as a cool project but I have 100's and need something higher level.
Message 8 of 15
(4,326 Views)
That was my bail out. Big pipe network 2D Image and overlay the pumps,valves, tanks...that need to show visual changes but I was hoping to avoid that approach.  It just adds another layer I was hoping to avoid.
Message 9 of 15
(4,324 Views)
I was able to make a decoration this small (compared to a standard numeric input for scale).  I can't think that anything smaller would be even useful.Capture.PNG
Bill
CLD
(Mid-Level minion.)
Message 10 of 15
(4,304 Views)
