Smooth XY Data of a Closed Curve
Hi. I am looking for suggestions on how to smooth XY Data that looks like the attached, a closed curve. The Filter vis I have looked at all use X but not X and Y.
Thanks.
Chris Walker
Certified Labview Developer
(3,716 Views)
Accepted by topic author chris_1243
Have you tried either:
a) using B-Spline Fit?, or
b) smoothing X and Y independently and recombining to give your smooth curve?
You may want to duplicate your data in the fit so that you get a more continuous curve at the end-points.  Here's a quick, rough example:
(3,648 Views)
That worked. Thank you!
Chris Walker
(3,563 Views)
