to send data one after another through visa write
hello sir, i want to send 8 byte of hexadecimal data one after another with different delay between them through visa write.
sir can u help me this by telling the solution?
Message 1 of 11
(4,270 Views)
If you have an array of bytes, just have the VISA Write inside a for loop and pass in the array. If you don't have an array, create one with the String to Byte Array function.
Message 2 of 11
(4,260 Views)
There are several serial io examples that ship with LabVIEW. Give one them a try and then get back to use with specific questions.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 11
(4,149 Views)
sir ,
i want to send different 8 bytes one after another.
in for loop ,how can i send different bytes ??
Message 4 of 11
(4,087 Views)
Your 8 bytes just needs to be in an array. Show a snippet of your code.
Message 5 of 11
(4,066 Views)
sir,
the snippet is attached below.
Message 6 of 11
(4,032 Views)
Nothing attached.
Message 7 of 11
(4,030 Views)
sorry sir it was a connection problem 😞
now i have attached the file.
Message 8 of 11
(4,023 Views)
That's not a snippet....
Message 9 of 11
(4,018 Views)
It's not even LabVIEW.
Message 10 of 11
(3,993 Views)
