Snap to closest graph point
Do you want the closest point in terms of pixel distance or in terms of absolute distance. Since your x and y scales have very different scale, there will be a large difference between the methods.
Message 11 of 16
(1,316 Views)
I think pixel distance would suffice for my needs
I have not lost my mind, it's backed up on a disk somewhere
Message 12 of 16
(1,314 Views)
Accepted by PauldePaor
Message 13 of 16
(1,310 Views)
Of course you still need to polish it up, for example you need to add an event for the stop button. Also the subVI code is a bit messy. 😉
Message 14 of 16
(1,293 Views)
Thanks very much for your help altenbach. Your knowledge holds no bounds
Message 15 of 16
(1,287 Views)
I know it's been like 8 years since this response, but I want to thank you for your incredible yet simple and elegant solution. I've been struggling with this problem for some years and I knew that I should use pixels to find the closest point, but I could never put together a solution.
Just threw off the window half of my code and pasted yours and worked like a charm.
Thank you, mr. Altenbach.
Message 16 of 16
(832 Views)
