‎12-14-2006 05:29 PM
‎12-18-2006
04:35 PM
- last edited on
‎06-06-2026
10:55 AM
by
Content Cleaner
RF328,
Here is a document that may be helpful in getting started with SoftMotion. It explains the architecture of the FieldPoint examples in the Example Finder:
http://www.ni.com/pdf/manuals/371331b.pdf
Which FieldPoint modules are you using? One possibilitiy is that the channels specified in the examples don't match up with the hardware that you are using. When you ran the examples, did you receive any errors or did it run without moving your motor?
Chris M.
Applications Engineer
‎12-19-2006 06:23 AM
Hello CMal
Thank you very much for your reply.
I have gone through the Softmotion manual. It helps but not fully helpful.
Is there any better examples or readout on softmotion that I can refer to.
I'm using FP2000 & LV7.1 RT.
Is LV 8 RT has some extra features compared to LV RT7.1 ? If so, I can always opt for LV 8 instead of 7.1
I've searched the web, can't find any good examples on softmotion.
Anyone that has experience in Softmotion please give some general tips.
Thank you in advance
‎12-20-2006 06:26 PM
RF328,
The FieldPoint SoftMotion example in the Example Finder is the only one that ships with LabVIEW, and I don't believe there are others for use with FieldPoint. Part of the reason for this is that any other examples would be build around the same structure as this example. You mentioned that you modified parts of this example for your hardware setup. Can you explain which parts you modified? Also, you said that you are using the FP2000 controller, but what modules are you using? Is your system set up for encoder or analog feedback.
In general, writing code with RT 8.0 or later is no different from RT 7.1. The main difference is that deployment is much easier with RT in the newer versions of LabVIEW. It allows you to deploy to multiple hardware targets, develop code that will run on host and target in parallel.
Chris M.
