Softmotion module only runs on labview 32 bit and not labview 64 bit
Good day everyone,
I downloaded the softmotion module for my Labview 2013 64 bit however when i try to create a new solidworks assembly there is no option for that.
But when I installed the 32 bit version of Labview 2013 I was able to see the option to create a new solidworks assembly.
Why can't I see the option for the Labview 2013 64 bit ?
P.S I am using Solidworks 2014 64 bit Premium .
Thanks 🙂
Below is the 64 bit
Below is the 32 bit
(3,494 Views)
Accepted by Izy
The softmotion module is not supported for 64-bit LabVIEW.  You can see what we support in the link below.
https://www.ni.com/en/support/documentation/compatibility/09/national-instruments-product-compatibil...
(3,487 Views)
It looks like that module only runs under 32  bit LabVIEW.
see page 2 of https://www.ni.com/docs/en-US/bundle/372876e/resource/372876e.pdf
(3,484 Views)
