Software to for cDAQ 9174
I have one chassis  NI cDAQ 9174 Part number 781157-01 and one AI module part 779516.
Unfortunately, the system builder is no longer in the business and the PC contain the Data Acquisition System is now degraded and phase out.
Our plan to get new PC to install software to interface with cDAQ 9174.
May i know what software module required to interface with cDAQ 9174 and what software required to write a visual program to read, record, visually display 2 pressure transducers connected to AI module.
thanks so much for your help.
(2,477 Views)
Accepted by DVTruong
You can use DAQExpress or FlexLogger Lite to acquire and view signals from DAQ.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kFD7SAM&l=en-US
https://www.ni.com/en/support/downloads/software-products/download.flexlogger.html#544232
Santhosh
Soliton Technologies
(2,435 Views)
Thanks so much for your advise. Just to confirm that Flexlogger is sufficient for communicating with chassis and no additional driver required, is it true?
(2,420 Views)
FlexLogger is an application, you will need DAQmx driver, I believe it will automatically install it as well.
Santhosh
(2,412 Views)
