Solid BG color for numeric indicator
I am trying to programmatically set the BG colour for a Numeric indicator by feeding a color constant to the relevant property node as in the attachment.
However I am only getting a outline color instead of solid color background. Unable to get over this issue.
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(3,411 Views)
Accepted by topic author MogaRaghu
You must use Numeric Text.Text Color.BG Color instead of Numeric Text.Color.BG Color.
(3,404 Views)
Thanks. It worked.
Also I noticed another thing in the process ....
When you right click the Property node , there is an option for Name Format. And when you choose "Short" which is what I had orginally done, it simply reads "NumText.BGColor" for both options. When I chose the "Long" option I could see the difference and chose the right one.
Raghunathan
(3,365 Views)
