SolidWorks.LabView error 70217
Hi!
I´m trying to make a project witch solidworks and Labview, the problem is that when im run the VI, appears a message with the error
70217
I´ve tried to add nes axis, the scan engine runs and the simulation in solid works runs too hte problem is in the blocks diagramm
could you help me please??  It´s a very importante work
(3,826 Views)
Hello majo_90,
Have you tried the steps mentioned in the following forum post?
Error -70217 when trying to run NI SoftMotion/SolidWorks:
http://forums.ni.com/t5/Motion-Control-and-Motor-Drives/Error-70217-when-trying-to-run-NI-SoftMotion...
Best regards.
David P.
www.ni.com/soporte
(3,793 Views)
