Solving ODE that uses a max() function
After much, much debugging on my end, and further examination of how the equations should work, I think I've got it. Thanks so much for the help!
Message 11 of 13
(1,041 Views)
Can you post a brief summary of the things you learned or found so that someone who comes across this thread in the future can learn from your experience?
Lynn
Message 12 of 13
(1,004 Views)
Sure thing.
I found that the biggest bugs were squashed by rectifying unit discrepancies between A pump, B pump, and the units of the differential equation. This also reduced the solutions sensitivity to h. As always, unit tests and modularity helped a lot with debugging.
Finally, I was using the wrong values for X0, so I shot an email to the author of the paper in question to get reasonable estimates.
Message 13 of 13
(980 Views)
