Some doubtful questions in LabVIEW Fundamentals Exam
In the Destination section select the desired file type (Printer, HTML file, RTF file, or Plain text file). Click Next.
  • Printer- Edit the Page Setup and Margins sections then click Next. Edit the Printer settings then click Print.
  • HTML- Select the desired image format and color depth then click Save.
  • RTF- Select the desired color depth then click Save.
  • Plain Text- Select the character limit per line then click Save.
Message 51 of 55
(1,354 Views)
And...may I know what this for??
Message 52 of 55
(1,334 Views)
@JÞB wrote:
All of the following statements regarding SubVIs are true, EXCEPT:
A   They require less memory.
B   They allow for easier debugging.
C   They allow you to use the same code for many future applications.
D   All of the above statements are true.
I'd say the question is badly written. A is only true in regards to the applikation if they're used several times, so it should be changed to "The application will require less memory" (which is true in some 98% (wild guess) of cases).
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 53 of 55
(1,299 Views)
Forget about the technicalities in answer A.  It is a badly written question because of logical fallacies.  The combination of "all is true, EXCEPT" along with answer D "all of the above are true" will never make any sense.
Let's say A B C are all true.  Then the answer D is the only remaining answer.  But it says all of the above are True, so it must also be true.  There is no False answer, so there is no answer.
Let's say A is false, B and C are true.  Then then answer A seems to be the correct answer.  But D must also be a correct answer because is says all of the above are true which is not true because you've already determined A is false.
So this question will either have no correct answers or 2 correct answers.
Message 54 of 55
(1,276 Views)
Just some tips to answer this question.
3.In LabVIEW, you may print to all of the following, EXCEPT:
A   Printer
B   HTML
C   Plain Text
D   All of the above are possible printing options
Regards
Message 55 of 55
(1,264 Views)
