Some doubtful questions in LabVIEW Fundamentals Exam
1.Probes on the front panel can be attached to:
A. Controls
B. Indicators
C. Graphs
D. None of the above.
2.When should Tasks be used in a DAQmx application?
A. If you want to perform channel acquisitions in a distinct order.
B. If you want to sample channels with similar scaling.
C. If you want to sample channels wirh similar timing and triggering.
3.When is the best place to adjust the gain for a DAQ channel?
A. the Gain input terminal of the DAQ Assistant.
B. Measurement and Automation Explorer (MAX).
C. the Input Specifications when setting up the DAQ Assistant.
D. the Set Gain VI, located in the DAQmx palette.
I am not sure which answer is the correct one, who can provide some advising answer for those questions? Thanks!
帖子被hmqi2002在09-15-2006 03:18 AM时编辑过了
Message 1 of 55
(8,019 Views)
this would be my solution
1-D ( probes are for block diagram and not front panel)
2-C
3-C
ppl, am I right?? Smiley Wink
Message 2 of 55
(7,975 Views)
The above is also my answer! :)
Message 3 of 55
(7,928 Views)
For the first question, is it possible for probes to be attached to indicators?
In LabVIEW 7.1 and LabVIEW 8.0, I can right click a wire and select "Custom probe>>Controls" to specify a indicator to display the value of the wire.
Message 4 of 55
(7,927 Views)
Yes you can but it not attached to any front panel control or indicator, it is attached to the wire on which you created it from.
Joe.
"NOTHING IS EVER EASY"
Message 5 of 55
(7,889 Views)
Thank you very much!
Message 6 of 55
(7,836 Views)
i also have many doubts those r as follows
1.the best method to pass data between same vi
a.wire
b.global variable
c.local variable
d.all the above
2.what is offset past match o/p node of match pattern vi
a.index of i/p string of first char of the aftersubstring o/p node
b.index of the next match relative to the previous match in input string if multiple matches exist.
c.index of the next match relative to the first char in i/p string if multiplematch exist.
d.index in i/p string of the first char of match sustring output node
3LabView executes block diagram code based on what programming layaout?
a.left to right programming executed startingon the leftand right on the block diagram.
b. data flow model block diagram executes dependent on flow data.
c.top to bottem
d.control flow the seqential order.
4. Daqmx channel and virtual channels are a collection of property setting that inclue all of the following
a.scalling information
b.physical channel
c.base i/o address
d.type of measurement
Message 7 of 55
(7,140 Views)
I am very new to LabVIEW, but question 1 is definitely a wire, because of the data flow principle and question 3 is definitely b, the data flow principle.
BTW: the question with the probes on the front panel is nasty 😉
Pattos
LabVIEW Gretchin
Message 8 of 55
(7,124 Views)
have some doubt in Labview....
How can we  use software(VI) designed in Labview to a system which doesn't have Labview.........
i know this is basic question ....have tried making an Exe file also an installer but none of them worked!!!!
Message 9 of 55
(7,087 Views)
Message 10 of 55
(7,085 Views)
