Some doubtful questions in LabVIEW Fundamentals Exam
Hi pradnaveen,
I would say that question 5 is answer c, because the minimum resolution of a 12 bit board in a 10V Range is 0,00244 V which means, that a 0,0026 V change will be detected.
Pattos
LabVIEW Gretchin
Message 21 of 55
(5,640 Views)
Thank u for ur answer
Message 22 of 55
(5,632 Views)
Can someone tell rest of the answers of question
Message 23 of 55
(5,630 Views)
1 Which VI architecture allows the user to run several tasks concurrently?
A   Multiple Case Structure VI
B   Parallel Loop VI
C   State Machine VI
D   None of the above
 2.Under which of the following settings would you not apply a gain to your signal?
A   5 V signal with 0-10 V ADC range
B   10 V signal, with 0-10 V ADC range
C   10 V signal with 0-5 V ADC range
D   1 V signal with 0-10 V ADC range
3.In LabVIEW, you may print to all of the following, EXCEPT:
A   Printer
B   HTML
C   Plain Text
D   All of the above are possible printing options
4.DAQmx channels and virtual channels are a collection of property settings that include all of the following, EXCEPT:
A   scaling information.
B   physical channel.
C   type of measurement.
D   base I/O address.
5.How does changing a DAQ board from a 0-10 volt range to a -10 to 10 volt range, affect the minimum voltage change that can be detected?
A   There will be no effect on the minimum voltage change that can be detected.
B   The minimum voltage change that can be detected will be split in half.
C   The minimum voltage change that can be detected will depend inversely with the resolution of the board.
D   The minimum voltage change that can be detected will be doubled.
6.What feature does LabVIEW include in order to allow a fast programming start from a common VI architecture?
A   VI Patterns
B   VI Templates
C   VI Starters
D   VI Guides
for
1.c
2.a
3.a
4.a
5.c
6.b
Am i correct friends pls clear me
if i am wrong explain plzzzzzzzzzzz
Message 24 of 55
(5,616 Views)
If both boards have the same resolution, then D is correct.  If both boards were 12 bit, then the 0-10 board would have a 0.00244 resolution, the -10 to +10 would have a 0.00488 resolution.
Othewise, I would say that C is correct in general.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 25 of 55
(5,597 Views)
Your answers to 1,2,3, and 4 are wrong.
What about a state machine runs in parallel?
You would apply a gain of 2 to the 5 volt signal
Yes, you may print to the printer.
Scaling information is included with a task/channel
Message 26 of 55
(5,585 Views)
See below
Your Answer
Correct Answer
 I'd suggest a lot more practicing and using LabVIEW before taking any CLAD exams.
pradnaveen wrote:
ok tell me if i am correct pls  apply
1.Which VI architecture allows the user to run several tasks concurrently?
B   Parallel Loop VI
C   State Machine VI
D   None of the above
State Machines give a way to control sequencing.  Parallel Loops allow things to run in parallel.
2.All of the following statements regarding SubVIs are true, EXCEPT:
A   They require less memory.
B   They allow for easier debugging.
C   They allow you to use the same code for many future applications.
D   All of the above statements are true. Correct.  Note.  SubVI's can use a little bit more memory, but they also allow you to replace duplicated code thus greatly reducing the memory requirements.
3.Under which of the following settings would you not apply a gain to your signal?
A   5 V signal with 0-10 V ADC range  Gain of 2
C   10 V signal with 0-5 V ADC range Gain of 1/2
D   1 V signal with 0-10 V ADC range Gain of 10
4.In LabVIEW, you may print to all of the following, EXCEPT:
A   Printer
B   HTML
C   Plain Text Of course you can print to a printer.  Since LV is graphical, plain text might be a problem.
5.Which DAQ board will allow for the detection of a 2.6 mV change in a signal if a 0-10 volt range was selected?
A   12-bit board This might be the correct answer, it is close to the 2.44 mV change as shown in the explanation for D.  But it would be a little generous round off error.
B   16-bit board
C   Both A. and B.
D   None of the above 10V / 2^12 is .00244 V or 2.44 mV.  10V/2^16 is 0.153 mV
6.DAQmx channels and virtual channels are a collection of property settings that include all of the following, EXCEPT:
B   physical channel.
D   base I/O address. Correct.
7.How does changing a DAQ board from a 0-10 volt range to a -10 to 10 volt range, affect the minimum voltage change that can be detected?
C   The minimum voltage change that can be detected will depend inversely with the resolution of the board. Question isn't talking about resolution, but the range of the board.
FOR
1.c
2.d
3.a
4.a
5.b
6.d
7.c
Tell me if i am correct or not and if wrong tell me the reason please
Message Edited by Ravens Fan on 01-05-2010 10:35 AM
Message 27 of 55
(5,594 Views)
B   16-bit board
C   Both A. and B.
The question says "will allow for the detection of a 2.6 mV change"  - both a 12bit board and a 16bit one will "allow for" detection of a 2.6mV change, although neither have that exact resolution, making the correct answer C  (I think!)
Message 28 of 55
(5,580 Views)
Printing to a plain text file is possible, at least with LabVIEW 8.2. Granted, not much is conatined in the file, basically the vi path, last modified date/tiem, and current revision number.
-AK2DM
Message 29 of 55
(5,577 Views)
B   16-bit board
C   Both A. and B.
Yes.  I think you're right.  I reinterpreted the question in my mind to something different than what is asking.
Message 30 of 55
(5,566 Views)
