Some doubtful questions in LabVIEW Fundamentals Exam
piyushup wrote:
have some doubt in Labview....
How can we  use software(VI) designed in Labview to a system which doesn't have Labview.........
i know this is basic question ....have tried making an Exe file also an installer but none of them worked!!!!
You should start a new thread with this question since it has nothing to do with the LabVIEW Fundamentals Exam, so I have no idea how you found your way inside this thread. You will also need to provide better information than "none of them worked!!!!". This means nothing. Did you get error messages? If so, what were they? Did LabVIEW crash? Did it blow up? Also indicate which version of LabVIEW you are using since the process of making an executable is different for LabVIEW versions prior to 8.0.
Message 11 of 55
(3,485 Views)
Don't hijack a completely unrelated thread.
Since you have built an exe, then you already have the answer to your question. Simply saying something does not work is not a good description of the problem.
Message 12 of 55
(3,482 Views)
yeah i think u guys are right....
sorry if i broke some rules.....
let me explain my question in a different thread... with proper explaination...
Message 13 of 55
(3,470 Views)
These r some of my doubts
pls clear it
1.Probes on the front panel can be attached to:
A. Controls
B. Indicators
C. Graphs
D. None of the above.
2.When should Tasks be used in a DAQmx application?
A. If you want to perform channel acquisitions in a distinct order.
B. If you want to sample channels with similar scaling.
C. If you want to sample channels wirh similar timing and triggering.
3.When is the best place to adjust the gain for a DAQ channel?
A. the Gain input terminal of the DAQ Assistant.
B. Measurement and Automation Explorer (MAX).
C. the Input Specifications when setting up the DAQ Assistant.
D. the Set Gain VI, located in the DAQmx palette
5.Which VI architecture allows the user to run several tasks concurrently?
A   Multiple Case Structure VI
B   Parallel Loop VI
C   State Machine VI
D   None of the above
6.All of the following statements regarding SubVIs are true, EXCEPT:
A   They require less memory.
B   They allow for easier debugging.
C   They allow you to use the same code for many future applications.
D   All of the above statements are true.
7.Under which of the following settings would you not apply a gain to your signal?
A   5 V signal with 0-10 V ADC range
B   10 V signal, with 0-10 V ADC range
C   10 V signal with 0-5 V ADC range
D   1 V signal with 0-10 V ADC range
Message 14 of 55
(3,427 Views)
What do you think the answers should be.
p.s. These exact same questions have been discussed in other threads.
Message 15 of 55
(3,425 Views)
 PLs i am really very doubtfull ab these questions pls help me .......
B   Parallel Loop VI
C   State Machine VI
D   None of the above
In LabVIEW, you may print to all of the following, EXCEPT:
A   Printer
B   HTML
C   Plain Text
D   All of the above are possible printing options
Which DAQ board will allow for the detection of a 2.6 mV change in a signal if a 0-10 volt range was selected?
A   12-bit board
B   16-bit board
C   Both A. and B.
D   None of the above
DAQmx channels and virtual channels are a collection of property settings that include all of the following, EXCEPT:
A   scaling information.
B   physical channel.
C   type of measurement.
D   base I/O address.
How does changing a DAQ board from a 0-10 volt range to a -10 to 10 volt range, affect the minimum voltage change that can be detected?
A   There will be no effect on the minimum voltage change that can be detected.
B   The minimum voltage change that can be detected will be split in half.
C   The minimum voltage change that can be detected will depend inversely with the resolution of the board.
D   The minimum voltage change that can be detected will be doubled.
Message 16 of 55
(3,413 Views)
As Dennis said, please try to answer them yourself.  Then we will tell you whether you are right and wrong and why.
Also search the forums for the questions, as most if not all of these questions have already been asked and answered in other message threads.
Message 17 of 55
(3,412 Views)
ok tell me if i am correct pls
1.Which VI architecture allows the user to run several tasks concurrently?
B   Parallel Loop VI
C   State Machine VI
D   None of the above
2.All of the following statements regarding SubVIs are true, EXCEPT:
3.Under which of the following settings would you not apply a gain to your signal?
4.In LabVIEW, you may print to all of the following, EXCEPT:
A   Printer
B   HTML
C   Plain Text
5.Which DAQ board will allow for the detection of a 2.6 mV change in a signal if a 0-10 volt range was selected?
A   12-bit board
B   16-bit board
C   Both A. and B.
D   None of the above
6.DAQmx channels and virtual channels are a collection of property settings that include all of the following, EXCEPT:
B   physical channel.
D   base I/O address.
7.How does changing a DAQ board from a 0-10 volt range to a -10 to 10 volt range, affect the minimum voltage change that can be detected?
FOR
1.c
2.d
3.a
4.a
5.b
6.d
7.c
Tell me if i am correct or not and if wrong tell me the reason please
Message 18 of 55
(3,403 Views)
2.d
How do you say using a subvi will require less memory???(A)
Message 19 of 55
(3,400 Views)
when placiing a subvi in other vi i doesnt take much memmory thats y..... pls clear me if i am wrong
Message 20 of 55
(3,389 Views)
