Somthing strange happend to my vi
The scrollbar in my blockdiagram dissappeared and I can't move my block diagram. I opened the navigation window to see my block diagram but I didn't find anything but when I closed it I see my block diagram?
Could anyone help me about this problem?
Message 1 of 11
(3,871 Views)
Hi Ahmad,
helping might be a lot easier when you attach the vi...
Message 2 of 11
(3,858 Views)
All vis have at least 1 pane, and panes have a scrollbar property for visibility for virtical and horizontal, the scrollbar visibility can be set to always show (default mode) hide when running or always hide.  The property might have been changed to always hide.  Go to the pane property (this was a vi property in LV 8.? and earlie).  and let the scroll bars to show again.
r
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 3 of 11
(3,834 Views)
Sorry just noticed you said block diagram not front panel.  Are you in edit mode (ctrl+M)
Paul Falkenstein
Message 4 of 11
(3,832 Views)
I attached here my the block diagram picture. you can see that there are no horizontal or vertical scrolls
Message 5 of 11
(3,793 Views)
According to the image, there is nothing on the block diagram and you would not have scroll bars on a blank block diagram. Why didn't you attach the actual VI?
Message 6 of 11
(3,784 Views)
The scrollbars go away when the block diagram is empty. Are you sure you didn't delete everything on the diagram? Try dropping something to see if the scrollbars come back.
Chris
Message 7 of 11
(3,779 Views)
I'm sorry I attached another pic of my block diagram that contains a code but it as you can see the navigation window is blank and I can find my block?
Message 8 of 11
(3,770 Views)
a blank vi makes sense,  I was assuming that there was known code on the block diagram.  You can ignore my earlier suggestions if the diagram is blank.  In some ways it would be nice to remove scrolls and force diagrams to be 1 page max to force us to keep code simple.
Paul Falkenstein
Message 9 of 11
(3,766 Views)
I'd say that your blockdiagram is out of bounds. I encountered issues like that exclusevly in frontpanels up till now, but i ponder it possible, that this happens on the BD as well......
But what still bothers me: why don't you post the vi? Screenshots don't help much because we cannot see for ourself what the "feature" is and how we could maybe correct it!
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 10 of 11
(3,761 Views)
