There are no inputs or outputs on the DAQ assistant to connect to
Hi everybody,
I am new to labview and have run into some difficulties with the DAQ assistant.  I am running labview v8.0, NI-DAQmx v8.7.1 and  have a PCI-6224 DAQ installed.  It seems that when ever I drop the DAQ assistant (the instrument assistant, and the simulated DAQ has the same issue) onto the block diagram, and configure it, there are no inputs or output which I can wire a control or indiactor to.  Is there a step that I am missing somewhere?
Thanks in advance!
Message 1 of 12
(4,232 Views)
Can you post a VI that has these blocks in it so we can determine if we see the same thing?
Message 2 of 12
(4,230 Views)
Here you go...
Message 3 of 12
(4,227 Views)
I feel dirty, I used an assitant for the first time. 🙂 I double clicked on it in your vi, some config panels/tabs came up, clicked on OK and then it built some LabVIEW code around it. The assistant then had inputs and outputs to wire to.
Sounds like it did not build the code in your case, not sure as to why yet. This is new to me.
-AK2DM
Message 4 of 12
(4,208 Views)
Sorry, forgot to attach the end result. Note I did have errors come up, they may have been due to no DAQ cards in my PC.
-AK2DM
Message 5 of 12
(4,206 Views)
Is there any way that I can convert the daq_test[2] to version compatible with 8.0?
Message 6 of 12
(4,171 Views)
Here is that VI for LV 8.0
Message 7 of 12
(4,168 Views)
Thanks.  I can make connections to the DAQ assistant in the example you provided (though the DAQ assistant does not work when selected from the functions list). Now I just have to figure out why the DAQ assistant is not getting the data to the graph.
Message 8 of 12
(4,156 Views)
Accepted by topic author bry0n
Try to repair the DAQmx Driver through the control panels and see if that solves the problem.
How Do I Uninstall or Repair NI Software?
http://digital.ni.com/public.nsf/allkb/AC6ED75D3D93375686256E8E00245F0D
Jordan F
Message 9 of 12
(4,138 Views)
Reinstalling and repairing the drivers took care of the problem.  But, for some reason or antoher there is a problem when you leave the daq assistant and it builds the VI, it will crash when I configure a hardware DAQ.
Message 10 of 12
(4,132 Views)
