Sony remote camera SDK- problems with import shared library wizard
I'm trying to import a .dll file (Cr_core.dll)  I downloaded from Sony's site (all the package is attached to this massage, including .dlls, .h and user manuals) the file contains 21 function that should remotely control the camera including live video, image acquire, shutter control etc . They did not put a .h file with the same name, but sent a bunch of .h files in the folder app/CRSDK.
I tried using all of the .h files  from the list in the import wizard and the wizard does not succeed to parse the functions in the dll file.
I have (almost) zero knowledge in C++ and I'm not sure how to proceed from here.
I'm using Labview 2020 64bit (I tried the 32bit version and got an error)
I also tried to use the call library function VI directly, but I'm not sure how to define the functions parameters.
Does somebody have a quick solution for my problem? Did I took a task that is over my head?
Gilad Moses
Message 1 of 1
(1,964 Views)
