Sorting Clothing Items in Ascending Order
Hi everyone,
I’m working on a project where I need to sort an array of clothing items in ascending order based on a specific sequence. I have three types of clothing items: shoes, pants, and shirt. I want to arrange them in the following order: shoes, pants, and then shirt.
For example:
- Given the 1D string array: pants, shoes, shirt
The output should be: shoes, pants, shirt
- Given the array: pants, pants, shirt, shoes
The output should be: shoes, pants, pants, shirt
- Given the array: shoes, pants, pants, shirt, shoes
The output should be: shoes, shoes, pants, pants, shirt
I’m looking for a way to sort the array such that the items are ordered according to the specified sequence.
thank you!
Message 1 of 9
(1,185 Views)
Seems simple enough. What have you tried?
Message 2 of 9
(1,168 Views)
Accepted by maxnoder1995
This is how I would do it.
https://tmesystems.net/
Message 3 of 9
(1,167 Views)
and this is how I would do it. 😄
Of course if there could be unlisted items in the array or if we need to ignore upper/lower case, etc. a little bit more code is needed once we know the extra behavior needed.
Comments for the earlier solution posted:
Three stacked structure, two shift registers, two different output tunnels (conditional indexing on a while loop and a concatenating tunnel on a FOR loop), delete from array in a tight loop (big no-no!) all seems a bit convoluted for such a simple problem. 😄
Message 4 of 9
(1,159 Views)
I did it in key-value form and in a much more complicated way. It definitely makes a lot more sense when I see the solution
Message 5 of 9
(1,157 Views)
Thanks! its great
Message 6 of 9
(1,151 Views)
Or alternatively:
which you can easily extend in case you want to sort by multiple criteria.
Raphaël.
Message 7 of 9
(1,104 Views)
Just for fun. (i know it can be improved with Maps, but i'm still unused to those)
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 9
(999 Views)
Here's a simple "Count and Concatenate" solution that doesn't actually sort anything.
Message 9 of 9
(983 Views)
