Sound and vibration examples - activate or not ?
I am a student and I am using evaluation version of LV. I am trying to play with sound and vibration examples but I cannot see the block diagram only the front panel. It is writen to activate LV product. Do I need activate the SV toolkit to see the examples block diagram or does some evaluation version exist ?
(3,007 Views)
You just need to press Control and E simultaneusly
(2,999 Views)
It is definitely correct answer. Now I would like to have answer from someone who is less funny. There is screen picture explaining the question.
(2,989 Views)
Accepted by topic author charlie87
Hey Charlie,
Please refer to the following KnowledgeBase:
http://digital.ni.com/public.nsf/allkb/862567530005F09C8625675F00711756?OpenDocument
If you are using the evaluation version of LabVIEW, "you will not have access to block diagrams of VIs not available in the Base Development System."
Your options are:
1 - Purchase the Sound and Vibration Toolkit (and LabVIEW as well),
2 - Purchase the LabVIEW Student Install version of the Student Edition, (only this version includes measurements of sound and vibration): http://www.ni.com/labviewse/compare/
You can check with your university/college to see if they have purchased the toolkit.
Hope this is useful,
Norbert
(2,981 Views)
