Source Distribution for Earlier Versions
I have a large project built in 8.6 that i'm trying to create a source distribution for. Is it possible to make the source dist. for an earlier version of labview (say 8.2)? Thanks
(3,004 Views)
Hello Paul,
Since source distribution is a collection of all VIs that are needed for your project, you would not be able to use the VIs in 8.6 for an earlier version of LabVIEW. However, you can use Save for Previous Version of your project to save ALL VIs in an earlier version of LabVIEW which then you can create the source distribution for that particular version of LabVIEW.
Andy Chang
(2,982 Views)
