labview student version 8.6.1 riemann zeta vi error running example file
Error 90051 wrong number of inputs for zeta function...
How to fix this..the mathscript vi is an internal vi...?
jjb thanks
(3,171 Views)
Might be matlab related..this vi uses an m file..you should have matlab
and might have to have the symbolic tool box working..maybe...
(3,151 Views)
MathScript does not rely on matlab at all. The example has a mathscript node and I don't see any .m file referenced.
Something seems corrupt in your installation.
Have you tried repairing your LabVIEW installation?
Message Edited by altenbach on 08-19-2009 08:29 AM
(3,150 Views)
Accepted by topic author labviewjoe
I have two computers running the same vi one runs
the other not...
I played around with the m files, opening and closing them...
I tried to load a new version of the zeta vi....and for
some reason...its fixed......
I looked at everything, paths,etc..must have been something
subtle....I even tried to edit the variable type..seeing that
I kept getting error 90051...
But, thanks for the input...its fixed..labview did not need to be
reinstalled...
JJ
(3,140 Views)
