04-17-2014 10:24 AM
I want to set up TortoiseSVN in LabVIEW but it's not listed in options. Should it be? If so how do I get there? Thanks in advance.
04-17-2014
10:42 AM
- last edited on
04-15-2024
01:47 PM
by
Content Cleaner
Hello PaulG,
Linked from the LabVIEW help, this KnowledgeBase article has a list of the SCC providers that are supported off-the-bat:
The TSVN tool I believe you're referring to is a JKI product, and I believe they offer a free evaluation version. It can be found on the LabVIEW Tools Network or as a standalone download here:
10:57 AM
- last edited on
04-15-2024
01:48 PM
by
Content Cleaner
TortoiseSVN is not part of the default Source Code Control providers.
As an alternative to the JKI option, you can use the TSVN Toolkit from Viewpoint USA.
It is a free toolkit that integrates to the project explore.
I find that is has more features than the JKI, and it match my needs.
04-17-2014 11:54 AM
I second the Viewpoint TSVN plugin!
The download from their website works with the 1.8.n version of Tortoise SVN
04-17-2014 12:12 PM
Thanks Tom. Since so many LVers use Subversion I was certain it was supported. I didn't even bother to check. Looks like I have some more work to do.
04-17-2014 12:16 PM
04-18-2014 07:56 AM - edited 04-18-2014 07:59 AM
@Dennis_Knutson wrote:
It is tortoise that does not comply with the Microsoft standard. I've never really missed it, though.
Funny you formulate it that way. The Micrsoft standard is build around their MS Source Safe product, which uses the somewhat outdated and cumbersome Checkin/Checkout paradigma. Aside from that it is awfully inadequate for most modern source control requirements and has in fact bugs that can eat your code for good. ![]()
As to Subversion integration: we don't do it but just use Tortoise SVN from the explorer interface. Works just as good for most situations. Haven't looked at TSVN or the Viewpoint solution yet but I kind of doubt they really use Tortoise SVN but instead most likely interface to the Subversion client instead.
04-18-2014 08:07 AM
No. It looks like the Viewpoint tool uses the command line interface for Tortoise SVN. You do a commit or revert and you get the Tortoise SVN windows.
04-18-2014 09:03 AM
Intergrated Tortoise SVN. Hmmm... >:)
04-21-2014 12:06 PM
Using Tortoise SVN with LabVIEW from the explorer window always works just fine for me. I start editing some VI file that is locked, as soon as I go to save (which is frequent) LabVIEW will say this file is read-only because I don't have the lock. It then brings up the dialog asking where to save it. The default location is where the read-only file is so I right click the file and say get lock. Then my file is not read-only and I can save again.
I have used the Viewpoint toolkit and don't think it really adds much for my usage. It does also create a bunch of quick drop functions which are nice but took up too many of my favorite key commands I already was using.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
