Sourcing to Process Calibrator
Hi everyone. I am handling the project using LabVIEW and I am very new to this graphical language. Please suggest me to overcome the problems.
The requirements are as follows:
1. Using LabVIEW I need to source the calibration points of temperature to the process Calibrator (DPI 620)
2. The calibration points must be sourced only on click on button.
3. In between if I need to check any channel that I have already sourced then I must make use of a control. And on next click on button the values must be sourced from that point only. For example, presently  I have sourced 60 deg Celsius of channel 3 and now I need to go back and source 20 deg Celsius of channel1. After sourcing 20 deg Celsius of channel1 the next point of channel 1 must be sourced on click on button instead of sourcing the next point of channel3..
    I have attached the code which I have done but it is not satisfying 3rd case i.e.., (After sourcing 20 deg Celsius of channel1 the next point of channel 1 must be sourced on click on button) this condition is not satisfying. Please help me out.
Thank you.
Message 1 of 1
(2,687 Views)
