Spaces and Tabs in Scan From String
Hi all.  I'm sure this question has been answered before, but I couldn't find exactly what I was looking for.
I'm having trouble with the scan from string function.  My format string specifies tabs (\t) as the delimiters between multiple parameters, however it's also using spaces.  As a result, a string which contains spaces causes it to fail on the next parameter because it's expecting a number but sees instead the remainder of the string.
Please see the attached.
If I replace the spaces with a token (in this case #SPACE#), I can read the string and the numbers correctly.  Then, I have to re-replace the tokens with spaces after reading it back.
Therefore, what I'm looking for is a way to specify the tab charater as a delimiter, but not the space character.
thanks for your help.
Message 1 of 9
(8,202 Views)
Instead  of %s use the character set [a-zA-Z0-9 ] (with a space at the end).
Ben64
Message 2 of 9
(8,190 Views)
That doesn't seem to work at all.
This is now my full format string:  %f\t%f\t[a-zA-Z0-9 ]\t%f\n
The Format Into String is now demanding a double input where the alphanumeric characters should go.
The scan from string gives only three outputs, all numeric.
Instead of treating [a-zA-Z0-9 ] as an indicator of a string, it's treating it as a literal string and inserting it as is.
Message 3 of 9
(8,186 Views)
I forgot to specify, you need to put the % before the character set.
Ben64
Message 4 of 9
(8,184 Views)
That does make a big difference.
But what if I want to include all printable characters, not just alphanumerics?
Message 5 of 9
(8,181 Views)
Accepted by LandBelenky
I would use %[^\t] in this case, which will read any character that isn't a tab.
Message 6 of 9
(8,175 Views)
Okay, that seems to work.  But now I'm confused.
Why does \t match both tabs and spaces, but ^\t reads spaces but not tabs?
Message 7 of 9
(8,171 Views)
It would be more accurate to say that %s doesn't match spaces.  Your original code fails trying to match the tab after the %s.
Message 8 of 9
(8,167 Views)
Have a look at "Format specifiers" in the LabVIEW help (in index search, format specifiers -> syntax elements).
Ben64
Message 9 of 9
(8,161 Views)
