Spatial Point Pattern Analysis
Hello all!
I have quite a challenge for anyone who is interested.  What I want to do is generate interpolated data points in a specific area on a graph.  My application allows a user to select multiple points on a plot for measurement.  These points have 3d coordinates, meaning X,Y and the measured data at this point, Z.  Now, what I want to do is create contour plots with this measured data.  My problem is, the user can generate a completely random point pattern.  Obviously, I want to be able to generate a set of interpolated points in the "general area" where the user created the points so I can draw contours wherever I want.  I know there are a few concepts and methods of doing this, but I wanted to know if anyone has already been through this type of  dilemma using LabVIEW.  I am currently running 7.1.
Thanks for the interest!
(3,916 Views)
No one knows about triangulation and spatial interpolation?
(3,909 Views)
There was some discussion on the subject some times ago. See this thread.
Chilly Charly    (aka CC)
(3,905 Views)
Thanks for the info!  I was already able to plot with Graph3d... my problem is that my data needs to be interpolated and isnt in a specific region.  Lets say the data is generally situated in a random shape.  I then need to interpolate the data in that region and then plot it to the graph.  Do you know how to do this?
(3,900 Views)
If the number of points is not too high, you could use Koji Ohashi's "tripolation.vi", that I found on the web some time ago. It's not very fast, and somehow buggy when there are more than a few tens of points, but it has a great advantage : it exists ! 😉
Message Edité par chilly charly le 05-08-2006 06:41 PM
(3,888 Views)
ok! Thanks for the help
(3,880 Views)
