What VI are you using to create the tables using the for loop? What VI (Append Table to Report.vi?) are you using to create the table at the end?
If you are using the Append Table to Report.vi to create the tables in the for loop, can you change the width of the columns and see expected behavior?
Let me know, and I should be able to help you out further.
Travis H.
Travis H.
LabVIEW R&D
