Spectogram or "Waterfall" digram plot
I am trying to get some plots (Figures) from MATLAB running into LabView.
One of the Plots should be kind of spectogram or "Waterfall diagram" View as attached (attached is a doppler example)
The Matlab code is this:
%calculate time
time = linspace(1,Tp*size(v,1),size(v,1));
%(sec)
%plot
imagesc(velocity,time,v-mmax,[-35, 0]);
colorbar;
xlim([0 40]);
%limit velocity axis
xlabel(
'Velocity (m/sec)');
ylabel(
'time (sec)');
How do I perform this with which subVi in Labview?
Thanks for any hints,
(3,095 Views)
First try is the intensity graph. See examples: Color Tables for Displaying the Spectrogram.vi  or Online Spectrogram Monitoring (Simulated).vi
Then have a look at the sound and vibration toolbox
Greetings from Germany
Henrik
LV since v3.1
(3,058 Views)
You might also try the mscript text execution computation node.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(3,038 Views)
