how to deploy activex object to compactrio
Hi people. I'm having a big issue here: i wrote a program to control an IP Camera. It's based on an ActiveX object, an library (format .ocx) that came with the cam driver. This program runs as expected on the PC, but when I deployed it to comactrio, it stopped woking because cRIO doesn't support ActiveX objects. Is there any way to run an ActiveX object from the compactRIO?
Thanks!!
(2,691 Views)
The OS on CRio's is VXWorks so there's no ActiveX support. Try to use the internet protocol on the cRio realtime controller to control your IP camera.
br Christian
(2,685 Views)
Can you give an example for that one!
I'm very appreciated to see it, thank you in advanced!
(2,605 Views)
