Spectrum using FFT
I am trying to convert a time-domain signal to frequency domain using FFT Spectrum (Mag-Phase).vi. As the time-domain signal is a laser pulse which is in the range of femtoseconds (10e-15s), i get frequencies in the THz range. My problem is now that the scale using FFT Spectrum starts at 0 Hz, I can't find a method to tune up the resolution of my spectrum...I only need a small range of frequencies in the THz range and not the whole range from zero on...
Somebody can help me how to convert my laserpulse to a spectrum? Using another vi?
Thanks in advance,
Christian
THINK G!! 😉
Using LabView 2010 and 2011 on Mac and Win
Programming in Microsoft Visual C++ (Win), XCode (Mac)
(3,119 Views)
It is not a problem to pick out parts of a FFT and discard non interesting parts. Then performing a FFT analysis the result is placed in "bins" The width of bins and how many will depend on sample rate and how many samples. I do not know what you know about FFT. But I give you some links. They are good reading. You can post again after reading them.
https://www.ni.com/en/shop/labview/using-fast-fourier-transforms-and-power-spectra-in-labview.html
http://zone.ni.com/devzone/cda/tut/p/id/4278
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,082 Views)
